ENG1999's avatar
ENG1999
3 years ago
Cyclone 10 GX PCIe pin setting
Dear Sir
I got a Cyclone 10 GX board.
I want to use the PCIe function.
So, I add the "Intel Arria 10/Cyclone 10 Hard IP for PCI Express" IP for PCIe function.
After generate the example verilog code, I got a Top module pcie_ed.v. (Gen1 X4)
I found it has a lot of input and output like below!!!
After I see the "https://www.intel.com/content/www/us/en/docs/programmable/683647/18-0/channel-and-pin-placement-for-the-gen1.html" information, I just know how to set xcvr_rx_inX andxcvr_tx_inX pin.
Could you please tell me, how can I set the pins ??
Thanks QQ!
input wire pcie_rstn_npor, // pcie_rstn.npor
input wire pcie_rstn_pin_perst, // .pin_perst
input wire [31:0] hip_ctrl_test_in, // hip_ctrl.test_in
input wire hip_ctrl_simu_mode_pipe, // .simu_mode_pipe
input wire pipe_sim_only_sim_pipe_pclk_in, // pipe_sim_only.sim_pipe_pclk_in
output wire [1:0] pipe_sim_only_sim_pipe_rate, // .sim_pipe_rate
output wire [4:0] pipe_sim_only_sim_ltssmstate, // .sim_ltssmstate
output wire [2:0] pipe_sim_only_eidleinfersel0, // .eidleinfersel0
output wire [2:0] pipe_sim_only_eidleinfersel1, // .eidleinfersel1
output wire [2:0] pipe_sim_only_eidleinfersel2, // .eidleinfersel2
output wire [2:0] pipe_sim_only_eidleinfersel3, // .eidleinfersel3
output wire [1:0] pipe_sim_only_powerdown0, // .powerdown0
output wire [1:0] pipe_sim_only_powerdown1, // .powerdown1
output wire [1:0] pipe_sim_only_powerdown2, // .powerdown2
output wire [1:0] pipe_sim_only_powerdown3, // .powerdown3
output wire pipe_sim_only_rxpolarity0, // .rxpolarity0
output wire pipe_sim_only_rxpolarity1, // .rxpolarity1
output wire pipe_sim_only_rxpolarity2, // .rxpolarity2
output wire pipe_sim_only_rxpolarity3, // .rxpolarity3
output wire pipe_sim_only_txcompl0, // .txcompl0
output wire pipe_sim_only_txcompl1, // .txcompl1
output wire pipe_sim_only_txcompl2, // .txcompl2
output wire pipe_sim_only_txcompl3, // .txcompl3
output wire [31:0] pipe_sim_only_txdata0, // .txdata0
output wire [31:0] pipe_sim_only_txdata1, // .txdata1
output wire [31:0] pipe_sim_only_txdata2, // .txdata2
output wire [31:0] pipe_sim_only_txdata3, // .txdata3
output wire [3:0] pipe_sim_only_txdatak0, // .txdatak0
output wire [3:0] pipe_sim_only_txdatak1, // .txdatak1
output wire [3:0] pipe_sim_only_txdatak2, // .txdatak2
output wire [3:0] pipe_sim_only_txdatak3, // .txdatak3
output wire pipe_sim_only_txdetectrx0, // .txdetectrx0
output wire pipe_sim_only_txdetectrx1, // .txdetectrx1
output wire pipe_sim_only_txdetectrx2, // .txdetectrx2
output wire pipe_sim_only_txdetectrx3, // .txdetectrx3
output wire pipe_sim_only_txelecidle0, // .txelecidle0
output wire pipe_sim_only_txelecidle1, // .txelecidle1
output wire pipe_sim_only_txelecidle2, // .txelecidle2
output wire pipe_sim_only_txelecidle3, // .txelecidle3
output wire pipe_sim_only_txdeemph0, // .txdeemph0
output wire pipe_sim_only_txdeemph1, // .txdeemph1
output wire pipe_sim_only_txdeemph2, // .txdeemph2
output wire pipe_sim_only_txdeemph3, // .txdeemph3
output wire [2:0] pipe_sim_only_txmargin0, // .txmargin0
output wire [2:0] pipe_sim_only_txmargin1, // .txmargin1
output wire [2:0] pipe_sim_only_txmargin2, // .txmargin2
output wire [2:0] pipe_sim_only_txmargin3, // .txmargin3
output wire pipe_sim_only_txswing0, // .txswing0
output wire pipe_sim_only_txswing1, // .txswing1
output wire pipe_sim_only_txswing2, // .txswing2
output wire pipe_sim_only_txswing3, // .txswing3
input wire pipe_sim_only_phystatus0, // .phystatus0
input wire pipe_sim_only_phystatus1, // .phystatus1
input wire pipe_sim_only_phystatus2, // .phystatus2
input wire pipe_sim_only_phystatus3, // .phystatus3
input wire [31:0] pipe_sim_only_rxdata0, // .rxdata0
input wire [31:0] pipe_sim_only_rxdata1, // .rxdata1
input wire [31:0] pipe_sim_only_rxdata2, // .rxdata2
input wire [31:0] pipe_sim_only_rxdata3, // .rxdata3
input wire [3:0] pipe_sim_only_rxdatak0, // .rxdatak0
input wire [3:0] pipe_sim_only_rxdatak1, // .rxdatak1
input wire [3:0] pipe_sim_only_rxdatak2, // .rxdatak2
input wire [3:0] pipe_sim_only_rxdatak3, // .rxdatak3
input wire pipe_sim_only_rxelecidle0, // .rxelecidle0
input wire pipe_sim_only_rxelecidle1, // .rxelecidle1
input wire pipe_sim_only_rxelecidle2, // .rxelecidle2
input wire pipe_sim_only_rxelecidle3, // .rxelecidle3
input wire [2:0] pipe_sim_only_rxstatus0, // .rxstatus0
input wire [2:0] pipe_sim_only_rxstatus1, // .rxstatus1
input wire [2:0] pipe_sim_only_rxstatus2, // .rxstatus2
input wire [2:0] pipe_sim_only_rxstatus3, // .rxstatus3
input wire pipe_sim_only_rxvalid0, // .rxvalid0
input wire pipe_sim_only_rxvalid1, // .rxvalid1
input wire pipe_sim_only_rxvalid2, // .rxvalid2
input wire pipe_sim_only_rxvalid3, // .rxvalid3
input wire pipe_sim_only_rxdataskip0, // .rxdataskip0
input wire pipe_sim_only_rxdataskip1, // .rxdataskip1
input wire pipe_sim_only_rxdataskip2, // .rxdataskip2
input wire pipe_sim_only_rxdataskip3, // .rxdataskip3
input wire pipe_sim_only_rxblkst0, // .rxblkst0
input wire pipe_sim_only_rxblkst1, // .rxblkst1
input wire pipe_sim_only_rxblkst2, // .rxblkst2
input wire pipe_sim_only_rxblkst3, // .rxblkst3
input wire [1:0] pipe_sim_only_rxsynchd0, // .rxsynchd0
input wire [1:0] pipe_sim_only_rxsynchd1, // .rxsynchd1
input wire [1:0] pipe_sim_only_rxsynchd2, // .rxsynchd2
input wire [1:0] pipe_sim_only_rxsynchd3, // .rxsynchd3
output wire [17:0] pipe_sim_only_currentcoeff0, // .currentcoeff0
output wire [17:0] pipe_sim_only_currentcoeff1, // .currentcoeff1
output wire [17:0] pipe_sim_only_currentcoeff2, // .currentcoeff2
output wire [17:0] pipe_sim_only_currentcoeff3, // .currentcoeff3
output wire [2:0] pipe_sim_only_currentrxpreset0, // .currentrxpreset0
output wire [2:0] pipe_sim_only_currentrxpreset1, // .currentrxpreset1
output wire [2:0] pipe_sim_only_currentrxpreset2, // .currentrxpreset2
output wire [2:0] pipe_sim_only_currentrxpreset3, // .currentrxpreset3
output wire [1:0] pipe_sim_only_txsynchd0, // .txsynchd0
output wire [1:0] pipe_sim_only_txsynchd1, // .txsynchd1
output wire [1:0] pipe_sim_only_txsynchd2, // .txsynchd2
output wire [1:0] pipe_sim_only_txsynchd3, // .txsynchd3
output wire pipe_sim_only_txblkst0, // .txblkst0
output wire pipe_sim_only_txblkst1, // .txblkst1
output wire pipe_sim_only_txblkst2, // .txblkst2
output wire pipe_sim_only_txblkst3, // .txblkst3
output wire pipe_sim_only_txdataskip0, // .txdataskip0
output wire pipe_sim_only_txdataskip1, // .txdataskip1
output wire pipe_sim_only_txdataskip2, // .txdataskip2
output wire pipe_sim_only_txdataskip3, // .txdataskip3
output wire [1:0] pipe_sim_only_rate0, // .rate0
output wire [1:0] pipe_sim_only_rate1, // .rate1
output wire [1:0] pipe_sim_only_rate2, // .rate2
output wire [1:0] pipe_sim_only_rate3, // .rate3
input wire xcvr_rx_in0, // xcvr.rx_in0
input wire xcvr_rx_in1, // .rx_in1
input wire xcvr_rx_in2, // .rx_in2
input wire xcvr_rx_in3, // .rx_in3
output wire xcvr_tx_out0, // .tx_out0
output wire xcvr_tx_out1, // .tx_out1
output wire xcvr_tx_out2, // .tx_out2
output wire xcvr_tx_out3 // .tx_out3
  • Wincent_Altera's avatar
    Wincent_Altera
    Hi
    We have not hear from you and this Case is idling. It is not recommended to idle for too long.
    Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
    Hence, This thread will be transitioned to community support.
    If you have a new question, feel free to open a new thread to get support from Intel experts.
    Otherwise, the community users will continue to help you on this thread. Thank you
    If you feel your support experience was less than a 9 or 10,
    please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
    Wincent_Intel
    Wincent_Altera
    I wish to follow up with you about this case.
    Do you have any further questions on this matter ?
    ​​​​​​​Else I would like to have your permission to close this forum ticket
    Wincent_Intel
