sfraser
5 years agoCyclone 10 GX Devel. Kit Board Test System Failed
I just obtained the Cyclone 10 GX Dev Kit and am trying to use the provided Board Test System to test out the features on the board. I can connect to the board via USB and have installed the...
A_G
5 years agoDear A,
I'm using the Cyclone 10 GX dev kit you mentioned (https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/cyclone-10-gx-development-kit.html) in your reply.
I have a similar problem where I get the "Failed to read production information ..." error 4 out of 5 times when it is configured with factory default design (GPIO/Flash: bts_config.sof). When it does work with GPIO/Flash firmware, if I were to configure it with any other example design (XCVR/DDR3/FMC) I always encounter the above error.
Could you please advice how to troubleshoot this issue.
Best regards
AG
