Cyclone 10 GX 3V IO Voltage
Hi Johnson Lee,
Just want to check, have you set the IO Standard of Bank 2L to 3.0V?
It is not a problem for an external devices that boot earlier than FPGA if you obey the pin state as shown in the user guide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10gx-51003.pdf (Page 273).
For example, LVDS I/O banks need to be tristated (Setting in Quartus) while power up and vice versa.
Thank You.
Hi YT,
I have a question on the reference file.
From the table below, it means the external IO pin should be in Tristate during FPGA boot up ?
If above rule can’t be followed, what will happen to the device?
And what should I do to prevent this?
Boot external devices later than FPGA ?
Please comment.
Thank you!
Johnson Lee
