JLee25
Contributor
6 years agoCyclone 10 GX 3V IO Voltage
Hi community, I have a new project based on C10 GX and I am debugging the IO problem. The device is 10GX220YF672, the IO bank 2L was design to interface 3V IO. I download a counter design to ver...
JLee25
Contributor
6 years agoHi YL,
Thank you for reply.
Yes, I did set the IO standard to 3.0V.
Attached is the qar file for your reference.
I test 2 boards with this configuration.
Both show the same status,
before config, gpio_0 is 3V, led_0 is 0.7V. After config, gpio_0 switch between 3V/ 0 V. led_0 is 0.9V/ 0V.
Johnson
JLee25
Contributor
6 years agoHi YT,
I just found the clock was not operated properly, amplitude is small..
I will check it and see if this is the root cause!
Thank you!
Johnson
