DiegoHa
5 years agoCyclon IV active serial configuration failed
I have a problem to configure a new custom FPGA Board.
We use a Cyclon IV (EP4CE22E22C8N) with an ISSI (IS25LP064A) Serial Flash Memory. (Similar to the Terasic DE0-Nano Board)
We use Quartus Pri...
YuanLi_S_Intel
5 years agoDo you have any update on this?
- DiegoHa5 years ago
Hi
The main problem was the *.jic file generation.
I have excepted that if I select a new configuration device, the default settings would work.
The Default Options/Boot info was set to Little endian instead of Big endian .
But I have still the problem than sometimes the configuration is not working.
Then i delete the db and the incremental_db folder in the project folder, recompile all and regenerate the jic file.
After that it works again.
I guess there is a problem during compilation or in the *.jic file generation.
Do you have an idea what the problem could be?
