DiegoHa
5 years agoCyclon IV active serial configuration failed
I have a problem to configure a new custom FPGA Board.
We use a Cyclon IV (EP4CE22E22C8N) with an ISSI (IS25LP064A) Serial Flash Memory. (Similar to the Terasic DE0-Nano Board)
We use Quartus Pri...
YuanLi_S_Intel
5 years agoHi,
Can you try to read back the JIC file stored in flash memory and compare with the JIC file which you are programming into it?
Also, may i know how many board is having this issue?
Also, can you probe the configuration pin and see if there is any abnormality?
Thank You.
