DiegoHa
5 years agoCyclon IV active serial configuration failed
I have a problem to configure a new custom FPGA Board.
We use a Cyclon IV (EP4CE22E22C8N) with an ISSI (IS25LP064A) Serial Flash Memory. (Similar to the Terasic DE0-Nano Board)
We use Quartus Pri...
YuanLi_S_Intel
5 years agoHi Diego,
Can you try to program with other quartus version?
Just to make sure, when you are programming using quartus programmer, the configuration mode setting is "JTAG configuration scheme" and the programming is successful with 100% right?
Can you try to program by not selecting blank check and verify?
Bruce
- DiegoHa5 years ago
Hi
I have tried it with Quartus version 18.1.0 Build 625 and Quartus version 20.1.1 Build 720
In both versions JTAG configuration scheme is working fine. 100%(Successful)
