DiegoHa
5 years agoCyclon IV active serial configuration failed
I have a problem to configure a new custom FPGA Board.
We use a Cyclon IV (EP4CE22E22C8N) with an ISSI (IS25LP064A) Serial Flash Memory. (Similar to the Terasic DE0-Nano Board)
We use Quartus Pri...
YuanLi_S_Intel
5 years agoHi,
Cyclone IV E has MSEL[3]. Can you please check if the pin is connected appropriate?
Also, have you try to program with SOF? is it working fine?
Thank You.
- DiegoHa5 years ago
Hi
according Cyclon IV Handbook page 173
Smaller Cyclone IV E devices or package options (E144 and F256 packages) do not have the MSEL[3]pin.Programming with the sof file works fine.
