DiegoHa
5 years agoCyclon IV active serial configuration failed
I have a problem to configure a new custom FPGA Board.
We use a Cyclon IV (EP4CE22E22C8N) with an ISSI (IS25LP064A) Serial Flash Memory. (Similar to the Terasic DE0-Nano Board)
We use Quartus Pri...
YuanLi_S_Intel
5 years agoHi,
What about MSEL3 status? Is it LOW as well?
What about the CONF_DONE status?
Also, can you check the following?
- The nCE, nCONFIG, nSTATUS and CONF_DONE pins are connected according to the recommended setup in the device handbook. If pull-up/pull-down resistors are required, ensure the resistor values are correct.
- The power supplies are ramped up to the appropriate voltage level according to the device datasheet and are stable throughout the operation
- Which quartus version are you using? Can you try with other newer quartus version?
Thank You.
- DiegoHa5 years ago
I use an EP4CE22E22 device in a E144 package which has no MSEL 3 Pin.
The CONF_DONE Pin is always low.
nCE is tied to GND
nConfig has 10k pullup to vccio (3V3)
nStatus has 10k pullup to vccio (3V3)
CONF_DONE has 10k pullup to vccio (3V3)vccio = 3.29V ripple +/-40mV
va = 2.49V ripple +/-40mV
vccint/vccpll = 1.21V ripple +/-30mVall supplies are stable during programming
I use Quartus Prime 20.1.1 standard revision
