9 years agoCVP on Arria 10
Hi, I have been trying to use CVP on Arria 10. This is hosted on a Ubuntu Host. I am using stock altera_cvp drivers. The core programs correctly and the drivers report success after the .rbf cop...
9 years agoHi,
I observed similar behaviour with Arria 10 GX PCIe card (Attila Instant-DevKit). When using altera_cvp driver, the FPGA configuration with .rbf file succeeds. But BAR access doesn't work, I also read 0xffffffff values instead of some known register bits. After warm restart the BAR access finally works. A warm restart is not needed if I remove the PCIe device first (e.g. via sysfs by "echo 1 > /sys/bus/pci/devices/0000\:42\:00.0/remove") and then do a bus rescan (e.g by "echo 1 > /sys/bus/pci/rescan"). Any clue how to debug this? Or did you already find a solution? Here, some infos from lspci. Before CvP configuration: $ lspci -d 0x1172:0xe003 -vv 42:00.0 Unassigned class [ff00]: Altera Corporation Device e003 (rev 01) Subsystem: Device 4e1b:4e0c Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 31 Region 0: Memory at f8300000 (64-bit, prefetchable) Region 4: Memory at f8000000 (32-bit, non-prefetchable) Capabilities: <access denied> Kernel driver in use: Altera CvP After CvP configuration (BAR access not working): $ lspci -d 0x1172:0xe003 -vv 42:00.0 Unassigned class [ff00]: Altera Corporation Device e003 (rev 01) Subsystem: Device 4e1b:4e0c Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Interrupt: pin A routed to IRQ 31 Region 0: Memory at f8300000 (64-bit, prefetchable) [disabled] Region 4: [virtual] Memory at f8000000 (32-bit, non-prefetchable) Capabilities: <access denied> Kernel driver in use: Altera CvP After PCIe device removal and bus rescan (BAR access working): $ lspci -d 0x1172:0xe003 -vv 42:00.0 Unassigned class [ff00]: Altera Corporation Device e003 (rev 01) Subsystem: Device 4e1b:4e0c Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Interrupt: pin A routed to IRQ 31 Region 0: Memory at f8300000 (64-bit, prefetchable) Region 4: Memory at f8000000 (32-bit, non-prefetchable) Capabilities: <access denied> Kernel driver in use: Altera CvP Thanks, agust
