CRubi
8 years agoCustom Board using Arria 10 (10AS057) with Marvell MVL88E1512
Hi, I have Arria 10 (10AS066) Evaluation kit and downloaded the TSE example (a10_soc_devkit_tse.tar.gz -https://releases.rocketboards.org/release/2017.10/tse/hw/) I was able to compile the project,...
CRubi
8 years agoHi SK Lim,
You mention that on rocketboard example the "control port of TSE IP is connected to HPS". May I know on the code or in the configuration that the TSE IP was connected to HPS.
I want to check my project if it I have the same implementation.
I'm targeting to replicate the approach use in TSE example from rocketboard.
Our software engineer is looking on the updating the driver.
I'm generating u-boot using the Makefile generated by BSP editor. How do you update the driver source? I asked this because the BSP editor outputs a default uboot-socfpga folder after sending the make command on uboot_bsp folder.
Allen Rubis
