CRubi
8 years agoCustom Board using Arria 10 (10AS057) with Marvell MVL88E1512
Hi, I have Arria 10 (10AS066) Evaluation kit and downloaded the TSE example (a10_soc_devkit_tse.tar.gz -https://releases.rocketboards.org/release/2017.10/tse/hw/) I was able to compile the project,...
CRubi
8 years agoHi SKLIM,
To answer your questions:
- Are you using HPS EMAC or soft TSE IP connect to the MCL88E1512 on your custom board? soft TSE IP
- Is either HPS EMAC or soft TSE IP interface working on your custom board? HPS EMAC is not connected on the board. I'm current looking to bring-up soft TSE IP which I have issue on bringing up on the board.
- Are you update the register map via MDIO as per MVL88E1512 datasheet? This is difference with the Marvel 88E1111 ( What A10 SOC board is using). May I know where is the MDIO register map on the TSE example- what folder or file? Does the TSE example uses NIOS?. I haven't done any update on the register map (MDIO
- If you are using soft TSE IP, some basic transceiver debug info is needed, are the following signals asserted? If not, which mean the transceiver link is not up and need to further debug on it.
a. rx_is_lockedtodata
b. rx_ready
c. tx_ready
On the TSE example, the rx_is_lockedtodata, rx_ready, tx_ready are not asserted. May I know where is it asserted on the TSE example.
