CRubi
8 years agoCustom Board using Arria 10 (10AS057) with Marvell MVL88E1512
Hi, I have Arria 10 (10AS066) Evaluation kit and downloaded the TSE example (a10_soc_devkit_tse.tar.gz -https://releases.rocketboards.org/release/2017.10/tse/hw/) I was able to compile the project,...
SengKok_L_Intel
8 years agoHi Allen Rubis,
In order to better understand the problem, could you please provide the following information?
- Are you using HPS EMAC or soft TSE IP connect to the MCL88E1512 on your custom board?
- Is either HPS EMAC or soft TSE IP interface working on your custom board?
- Are you update the register map via MDIO as per MVL88E1512 datasheet? This is difference with the Marvel 88E1111 ( What A10 SOC board is using).
- If you are using soft TSE IP, some basic transceiver debug info is needed, are the following signals asserted? If not, which mean the transceiver link is not up and need to further debug on it.
a. rx_is_lockedtodata
b. rx_ready
c. tx_ready
Regards -SKLIM (Intel)
