17 years agoCurrent consumption
hello, I'm working about new project on the Stratix III EP3SE50F780. I can't find the worst case current consumption of each voltage source. I know about the PowerPlay early power estimator but I ...
17 years agoThe worst case is difficult to calculate.
i.e. it will be when all FlipFlops and Outputs are toggling at the maximum frequency of your design. This is an unrealistic limit for all designs. So the maximum current for your LDO will depend entirely on your design and clock frequencies etc. I would use the PowerPlay tool and put in the maximum expected values for Toggle rate etc. Either that or put down the biggest regulator you can :)
