Current consumption during the secured key and encrypted data programming
That means you had a voltage ripple, and eventually the ripple exceed the max value of operating condition that triggers the device reset(you observed as device shutdown).
Please review your power delivery design for your PCB and make sure the decoupling capacitors are sufficient to supply the current required during ramp up and configuration.
Please use PDN tool to determine the power needed and how many decoupling required in your design.
regards,
Farabi
Hello Farabi, thanks for the reply.
I'm not sure if you caught my issue here: the device powers up and configures properly, which implies my PDN is good. And yes, I used Intel's PDN tool to estimate it. Later in design, I used PI simulations to verify that my caps and planes are up to the job.
The issue arises when the secure programming is used. For some reason, the current consumption during secure programming is higher than using "normal" programming. Do you know why is that, and how can it be mitigated?
best regards,
P.
