11 years agoCrossing clock domains?
I'm just learning about FPGAs (using VHDL) and have encountered metastability problems which I'm fairly certain are due to crossing clock domains. I have made a VGA controller (on a DE1 Cyclone...
11 years agoOk - thats fair enough
Because the CPU clock is so much slower than the FPGA clock, you could easily just sample the CPU clock and detect rising edges as enables in the FPGA clock domain (as anakha has already suggested).
signal cpu_clk_resync : std_logic_vector(3 downto 0);
signal cpu_clk_en : std_logic;
process(fpga_clk)
begin
if rising_edge(fpga_clk) then
cpu_clk_resync <= cpu_clk_resync(2 downto 0) & cpu_clk;
if cpu_clk_resync(2) = '1'
and cpu_clk_resync(3) = '0'
and cpu_clk_resync(1) = '1' -- ensure it really is stable and not metastable/bouncing
then
cpu_clk_en <= '1';
end if;
end if;
end process;
Then you can safely use any properly synchronised data
