MHEDA
7 years agoCritical Warning 16248 (pin is placed too close with ADC pins) and TSD use.
Hi, For my current project i use an IntelFPGA MAX10 (10M40DAF484) and i use a lot of the available IO's. Moreover, i need to use the internal temperature sensor. So i add the hard ADC IP and my own...
AnandRaj_S_Intel
7 years agookay,
TSD data need to be sampled by with reference voltage, We can use both internal/external reference voltage.
For your requirements, you can use Internal VREF & you can safely ignore the Critical Warning.
If we are not using ADC pin.
Anand
