MHEDA
7 years agoCritical Warning 16248 (pin is placed too close with ADC pins) and TSD use.
Hi, For my current project i use an IntelFPGA MAX10 (10M40DAF484) and i use a lot of the available IO's. Moreover, i need to use the internal temperature sensor. So i add the hard ADC IP and my own...
MHEDA
7 years agoI don't understand your answer.
You said that ADC Sampling is influenced by analog inputs. I agree, i read this point too in the IntelFPGA documentation. But TSD doesn't use input how it can be influenced by GPIO?
"TSD data need to be sampled by with refrence voltage" -> does it means by using an external reference voltage ? Or using internal reference is enough ?
Moreover i checked my pinout, and i use too many pins on those banks (1B and 8) to move them to the other banks.
