MHEDA
7 years agoCritical Warning 16248 (pin is placed too close with ADC pins) and TSD use.
Hi, For my current project i use an IntelFPGA MAX10 (10M40DAF484) and i use a lot of the available IO's. Moreover, i need to use the internal temperature sensor. So i add the hard ADC IP and my own...
AnandRaj_S_Intel
7 years agoHi,
It should not be an issue if you are not using analog pins of ADC and using appropriate banks for IO.
- Can you share information on the part number & IO banks used?
Anand
