11 years agocriteria for choosing best BER value
How do we determine a value as the best BER value considering many values obtained after running the auto sweep feature in transceiver toolkit. From my basic knowledge i understood that it must be as...
11 years ago --- Quote Start --- How do we determine a value as the best BER value considering many values obtained after running the auto sweep feature in transceiver toolkit. From my basic knowledge i understood that it must be as low as possible.But, there might be many more lower values below that BER value. So how to fix upon a value. --- Quote End --- In the transceiver toolkit, you can also specify a target BER and then run auto sweep. The sweep will stop when achieve the target. You can also set a tighter BER if you want more margin.
