8 years agoCreate own Avalon MM-Slave
Hi there I'm trying to create my first Avalon MM-Slave which should be accessible through a NIOS II softcore. In the end I just want a MM-Slave which has a conduit input and output for connecti...
8 years ago --- Quote Start --- Can you attach the RAM read-write logic used? --- Quote End --- Anand Raj, I'm not sure what RAM read-write logic you mean. Are you talking about the on-chip memory of the NIOS II? If yes, there was no explicit read-write logic generated by Qsys (see attached porject_overview_1.jpg). Or are you talking about the template I found on the internet (if yes then look at the attached file system_cpu_serial_interface_2.vhd)? Or does the avalon interconnect have a RAM for read- and write data (there are a lot of components generated for the interconne? --- Quote Start --- it may be because of that logic issue.Follow the timing diagram from below attachment https://www.altera.com/en_us/pdfs/li...ug_ram_rom.pdf --- Quote End --- I don't see the connection between my problem and the document you attached. Do you wanna say that I have a problem with a RAM or do you mean that there is a general timing issue with the Avalon bus? --- Quote Start --- (...) what have you set as the base address of this component? --- Quote End --- The base address of the component is 0x0008_1040 --- Quote Start --- And since you're using Signal Tap, what does the address look like on the master side instead of the slave side? --- Quote End --- This was also my intention and I did also capture a shot where the master signals are included (see attachment st_master_signals.jpg). But for me it is pretty hard to debug on the master side, since I don't know the master in detail. --- Quote Start --- I doubt it would make a difference, but what happens if you use just IORD and IOWR instead of the 32DIRECT commands you used? --- Quote End --- This is it! It makes a difference! If I use the IORD and IOWR it works as expected. But whats the difference between IOWR and IOWR32DIRECT?
