12 years agoCreate Interupt from HPS to NIOS II
Hello, I have an application which transfers data from the HPS to a NIOS II. I would like to use an interrupt to signal to the NIOS II from the HPS that new data is available. How can I do th...
12 years agoMay will use FPGA-GPIO pins ? Question to all.
Out pin to FPGA-LED may make request in Nios ? 64 lines from FPGA to GIC with interrupts is unidirectional ? I personally recommend polling -- Nios read memory writing from HPS and see pointer changing.
