17 years agocreate_clock with pre map signals....
I've gone through the online training for timing quest, I've read everything I can find in the user manual, and I'm still missing something.. I really want to be able to use create_clock and cr...
17 years ago --- Quote Start --- I've gone through the online training for timing quest, I've read everything I can find in the user manual, and I'm still missing something.. I really want to be able to use create_clock and create_generated_clock on a pre map net name. After mapping, the net names a all changed up (and with fine reason - optimization and all), and SDC files are not read until after mapping and before fitting.... It seems like there must be a way to do this more automatically without mapping first, running the gui, doing a bunch of searching, getting it wrong a bunch of times, retrying etc... One idea I had was the try to keep the wire around, even though that certainly may be less optiimal with wire generatedClockA /* synthesis keep = 1 */; // verilog But this doesn't keep the net around, or at least I can't see that it does (hmm, can I dump out a dump map netlist to verify this or not ? Meaning that if I try to use that net in the create clock command, it doesn't find that net. I guess the clock divider always sticks around, but it's buried down a few levels of hierarchy, as the report tells me *after* I've run fit... I'm must be missing something basic here, or are clocks really always a completely interactive setup everytime you change add or delete internal clocks??? --- Quote End --- Hi, normally timing constraints are applied to a design before synthesis and mapping, because the constraint should guide the tool to reach the design requirements. Why do you want to set the contraints on the pre-mapped netlist ? Kind regards GPK
