DB
7 years agoCRC in Cyclone V Devices
Hi, I have got questions regarding the CRC capability of Cyclone V devices: The following document describes the behaviour on pages 291 - 301: https://www.intel.com/content/dam/www/programmable/us...
DB
7 years agoHi JohnT,
thanks for your answer.
"It is define in the Quartus Setting."
--> Where is it defined?+
If you look into the time used, Tmin using ms while Tmax is in second. That is the reason of using different calculation.
--> But one time, I have a devision and one time, I have a multiplication. This can't be correct due to the units. If I devide by [s] it is not the same than multiply with [s], if I expect an result in [s].
--> Can you please clarify or give me an example, e.g. for the Cyclone V E A9. Therefore Tmin = 23ms and Tmax is 13.93s. So, how to calculate the minimum and maximum time for CRC of the whole device?
Thanks and best regards,
David
