17 years agoCRC design file for De1 development board
greetings everyone,
I would like to implement a CRC in my system. The problem is that I have only a DE development board so without SSRAM but only with a SRAM (data bus width= 16, address bus width=18). Which changes should I perform in the design files given by Altera so that it can work with my card?? it is a major matter for me because I have to do this before the end of my internship, so in 2 weeks! Thank you very much, éléa2 Replies
Hi vernmid,
Thank you for your help. in fact I try to do a tutorial given by altera based on CRC. www.altera.com/support/examples/nios2/exm-crc-acceleration.html I want to create a custom instruction to accelerate the CRC calcul. BUt first I want to include a CRC component in my system made with SOPC Builder. The problem is that, in the example given, the memory linked to the CRC component is a SSRAm and I do not have one on my board. Can I do this tutorial by replacing a SSRAM with a SRAM (givent that the SSRAM has a 32 bits data bus and my SRAm a 16 bits data bus)? éléa - Altera_Forum
Could you be more specific about what it is you are trying to do?
Are you trying to calculate the CRC of the contents of a particular external memory area for error checking purposes?
