15 years agoCPLD EPM240T Serious Burn down!!
Hi,I met a very bad problem when I use CPLD EPM240T. (1) Environment : in this project,it have 10 IO board with EPM240T,all these board connected through one back board.Between these EPM240T,t...
15 years agoEven a short circuit of one or more output pins, although violating the maximum ratings, isn't usually causing catastrophic failure of the device. Thus I assume, that a serious problem of violated supply or input voltage ratings is present in your design.
