GD76
5 years agoCPLD constraints
Where can I get information on locking all the macrocells through SDC file? The constraint editor document I have is talking about doing it through pin planner but like to do it through constraint SD...
- 5 years ago
Ganesan,
May I know if there is any update?
sstrell
5 years agoThe SDC file doesn't lock anything. It just provides timing requirements to the Fitter. I'm not sure what you mean by "locking macrocells".
GD76
5 years agoHow to lock the routing of some signals to macrocells so build to build the routing does not change.
- sstrell5 years ago
The best method for doing this is to use a block-based design flow where you divide your design into design partitions and then "lock down" each partition as you complete its optimization. See the block-based design flow user guide:
If you're using Standard instead of Pro, look in the documentation for the "incremental compilation" feature.
