14 years agoCPLD clock skew generation
I use an epm2210 CPLD and need to generate two internal clocks of 50MHz with 3 to 8ns phase difference. Any ideas?
14 years agoThanks for the reply.
My code decodes address,data,,cs and r/w from a processor bus. The data is written and read to a fifo based on fifo_read and fifo_write. Since the clock for the processor bus signals is the same as the fifo clock I just wanted a few ns delay between fifo_read/write (generated by a state machine) to make sure the fifo_clock is stable before the fifo_read/write happens. Without any phase difference between the closks the current design seems to give unpredictable read/writes results.
