12 years agoCPLD and SDRAM
Hello Is that the CPLD has enough resources to be able to control a SDRAM Thanks
12 years agoHi!
Erm, have a look at the datasheet and figure out the timing / clocks based on the clock-speed you've selected. SDRAM is a lot different from SRAM. The datasheet should have about 60 pages worth outlining the states / transitions. Not exactly sure what you mean by unloading the data.. Hope this helps, -Mux
