18 years agocoupla n00b Q's on libraries
Hi we just started using Quartus on my course and we've come up stuck trying to create a library the notes we have been following from Penn Uni give the code: -- Package declaratio...
18 years agoHi
so havelibrary ieee, work;
use ieee.std_logic_1164.all, work.basic_func.all; at the start of my code now, with basic_func.vhdl stored in my project directory but still have same errors. the main one being Error: VHDL Use Clause error at buzzer.vhd(4): design library "work" does not contain primary unit "basic_func" then Error: Ignored construct buzzer at buzzer.vhd(6) because of previous errors -thus- Error: VHDL error at buzzer.vhd(11): entity "buzzer" is used but not declared and strangely Error: VHDL error at buzzer.vhd(14): object "std_logic" is used but not declared as if even the ieee.std_logic_1164 package is not being used???? once again any help is much appreciated and much thanks for the help so far :)
