15 years ago
Counter in VHDL
I want to design a 16 bit counter with 1uSec resulution.
I have only 40MHz clock and can't use neither PLL or frequency divider.
I can use only the 40MHz global clock.
Can somebody recommend for VHDL design for 16 bit counter with resulution adjustment?
THX
GUY.
    Possibly.
    If you come up with other ideas, give them a go too and look at resource usages.
    Thank you!
    I want to implement it in minimum hardware. You think this is the most minimized option?
    Guy.
    run another counter at 40MHz. When it reaches a given number generate an enable that increases the main 16 bit counter.
