12 years agoCould someone have an idea?
Ok. I have 4 modules that it depends on GPIO or Switch Hi or Lo
module From_SPISlave() and module To_UART(); module From_UART() and module To_SPIMaster(); if (Switch is Hi) then I run the first: From_SPISlave() and To_UART(); if (Switch is Lo) then I run the second: From_UART() and To_SPIMaster(); How do I design this in top level? Thanks, Sean2 Replies
Modules are not run, they are placed like chips on a circuit board. It sounds like you need a mux....
Thanks Tricky,
In my design right now, I have these layout module Top(); switch; From_SPISlave(;;;;;;); To_UART(;;;;;;); From_UART(;;;;;;;); To_SPIMaster(;;;;;;); endmodule Do you have any pointers how to use mux? Sean
