14 years agoCould not find rtl_work.TB.vhd
The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design# Error: Error loading design # Pausing macro execution # MACRO ./PFC_run_msim_rtl_vhdl.do PAUSED at line 34 I remember to delete the work folder to be able to compile a library that need that according to a modelsim tutorial: http://doc.union.edu/118/se_tutor.pdf (http://doc.union.edu/118/se_tutor.pdf) I have to do vcom <vhdl files .vhd> # do this for all the files cause it had to be done in the work folder, this may have caused the issue. i'm lost, can anyone help me?.80 Replies
VHDL allows you to package components into libraries.
If you know how to use the tools, then its relatively easy to get libraries working. Since you are letting the tool create scripts for you, its a little harder. To make your life simpler, just edit the VHDL files with library ieee_proposed; use ieee_proposed.fixed_package.all; and change these two lines into the single line use work.fixed_package.all; Then both Quartus and Modelsim will look for all VHDL in the default work library. Cheers, Dave - Altera_Forum
--- Quote Start --- Leads to quartus compilation error: Error (10481): VHDL Use Clause error at producten.vhd(4): design library "ieee_proposed" does not contain primary unit "fixed_pkg" Error (10800): VHDL error at producten.vhd(4): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at pack.vhd(10): design library "ieee_proposed" does not contain primary unit "fixed_pkg" Error (10800): VHDL error at pack.vhd(10): selected name in use clause is not an expanded name Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 4 errors, 1 warning Error: Peak virtual memory: 316 megabytes Error: Processing ended: Thu Sep 13 18:56:45 2012 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:02 Error (293001): Quartus II Full Compilation was unsuccessful. 6 errors, 1 warning I'm trying the alternative method. PS: Properties->library-> rtl_work, if i return to erase rtl_work from the Properties->library-> rtl_work, quartus compilates ok. --- Quote End --- THIS ERROR IS POINTING TO MY PROJECT FILES INCLUDES!! But once again about ieeeproposed... The pack file is this: ------------------------------------------------------- -- Design Name : User Pakage -- File Name : Pack.vhd -- Function : Defines function for LFSR -- Coder : Alexander H Pham (VHDL) ------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; library ieee_proposed;use ieee_proposed.fixed_pkg.all; USE ieee.std_logic_arith.all; use IEEE.std_logic_unsigned.all; package Pack is type info is array (1 to 78) of sfixed (1 downto -16);-- 78= 8*8 + 14/16 bordes type templates is array (1 to 9) of sfixed (1 downto -16); end; package body Pack is end package body; But also my main includes: library ieee_proposed;
with no error.
If you referd to "change the library those two packages are compiled into, eg., right click on the files, and set the library to rtl_work" -> work
work leads to same situation as nothing there. - Altera_Forum
--- Quote Start --- Alternatively, just edit the VHDL files and change rtl_work to just plain work, and then it'll work fine. Cheers, Dave --- Quote End --- Sorry neither fixed_float_types_c fixed_pkg_c contains the rtl_work name, and if you refered to PFC_run_msim_rtl_vhdl.vhdl changes, it erases them. Alfonso. - Altera_Forum
--- Quote Start --- Since it sounds like you are using Quartus to run Modelsim, use Quartus to change the library those two packages are compiled into, eg., right click on the files, and set the library to rtl_work (I think that is how you do it). --- Quote End --- Leads to quartus compilation error: Error (10481): VHDL Use Clause error at ProducteN.vhd(4): design library "ieee_proposed" does not contain primary unit "fixed_pkg" Error (10800): VHDL error at ProducteN.vhd(4): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at Pack.vhd(10): design library "ieee_proposed" does not contain primary unit "fixed_pkg" Error (10800): VHDL error at Pack.vhd(10): selected name in use clause is not an expanded name Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 4 errors, 1 warning Error: Peak virtual memory: 316 megabytes Error: Processing ended: Thu Sep 13 18:56:45 2012 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:02 Error (293001): Quartus II Full Compilation was unsuccessful. 6 errors, 1 warning I'm trying the alternative method. PS: Properties->library-> rtl_work, if i return to erase rtl_work from the Properties->library-> rtl_work, quartus compilates ok. - Altera_Forum
Look at the Tcl script again. It already has the lines:
Note how the code is being compiled into the library work. Since it sounds like you are using Quartus to run Modelsim, use Quartus to change the library those two packages are compiled into, eg., right click on the files, and set the library to rtl_work (I think that is how you do it). Alternatively, just edit the VHDL files and change rtl_work to just plain work, and then it'll work fine. Cheers, Davevcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/altera/fixed_float_types_c.vhdl} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/PLL.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/altera/fixed_pkg_c.vhdl} - Altera_Forum
Hello, this is the testbench file i want to use, i'm planning to use this, in case you need to know it.
Alfonso - Altera_Forum
Good afternoon/Morning:
What i try to do is: 1st: vcom -work rtl_work fixed_float_types_c.vhdlvcom -work rtl_work fixed_pkg_c.vhdl
2nd they work as yesterday did then i close the console, cause if the console is stoped i cannot launch MS succesfully, and when i press the button rtl compilation (> and a register with a timing signal under > and the reg) it launches and then after a while: # ** error: (vsim-3170) could not find 'c:\users\alfonso\desktop\pfc\simulation\modelsim\rtl_work.tb_pfc_main'.# error loading design# error: error loading design # pausing macro execution # macro ./pfc_run_msim_rtl_vhdl.do paused at line 34
or Same happens if i launch pfc_run_msim_rtl_vhdl.do with nottepad ++ and write, save and close, and then launch rtl compilation: ------------------------------------------------------------------- transcript on if {[file exists rtl_work]} { vdel -lib rtl_work -all } vlib rtl_work vmap work rtl_work vcom -work rtl_work fixed_float_types_c.vhdl
vcom -work rtl_work fixed_pkg_c.vhdl vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/IHW_UART.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/altera/fixed_float_types_c.vhdl} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/PLL.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/altera/fixed_pkg_c.vhdl} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/Pack.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProducteS.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProducteE.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProducteO.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/SumaStep.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProdAnteriorNE.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProdAnteriorNO.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProdAnteriorSO.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProdAnteriorSE.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProducteSE.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProducteSO.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProducteNO.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProducteNE.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/ProducteN.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/CNN.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/PFC_main.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/SumaStep1.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/SumaStep2.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/SumaStep3.vhd} vcom -93 -work work {C:/Users/Alfonso/Desktop/PFC/TB_PFC_main.vhd} vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneii -L rtl_work -L work -voptargs="+acc" TB_PFC_main add wave * view structure view signals run -all ------------------------------------------------------------------- It is deleted which leads me to: # ** error: (vsim-3170) could not find 'c:\users\alfonso\desktop\pfc\simulation\modelsim\rtl_work.tb_pfc_main'.
--- Quote Start --- Hello and thank you for your involvement, i don't know how to make a permanent configuration of tcl commands, according to se_tutor (http://www.alteraforum.com/forum/se_tutor) chapter 14, Tcl commands are what we were typing on the modelsim console, but i've not found nothing talking about scripts. --- Quote End --- Scripts are just files that you run (source) in the Modelsim console. Basically you're just saving yourself some typing. --- Quote Start --- Please help me ... --- Quote End --- I'm trying, but you appear to be missing some fundamental experience with these tools ... so lets see if we can fix that. --- Quote Start --- PS: one thing if I use notepad++ to modify a .DO file, launching modelsim overwites it, so i don't know how to make permanent changes. --- Quote End --- I've never seen Modelsim overwriting files. How are you starting Modelsim? If you are starting Modelsim from Quartus, then it is probably Quartus that is modifying files, not Modelsim. Please review the modelsim_example.zip tutorial on using Modelsim posted in this thread: http://www.alteraforum.com/forum/showthread.php?t=32386 That example shows what a Modelsim Tcl script is. Please explain the steps you are performing with Quartus and Modelsim to have the problem with overwriting files. Cheers, Dave - Altera_Forum
Please help me i must have debugged my code for next wednesday, and i can't use modelsim due to errors. PS: one thing if I use notepad++ to modify a .DO file, launching modelsim overwites it, so i don't know how to make permanent changes. (http://www.alteraforum.com/forum/se_tutor)
