14 years agoCould not find rtl_work.TB.vhd
Hello, The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design...
14 years ago --- Quote Start --- Since it sounds like you are using Quartus to run Modelsim, use Quartus to change the library those two packages are compiled into, eg., right click on the files, and set the library to rtl_work (I think that is how you do it). --- Quote End --- Leads to quartus compilation error: Error (10481): VHDL Use Clause error at ProducteN.vhd(4): design library "ieee_proposed" does not contain primary unit "fixed_pkg" Error (10800): VHDL error at ProducteN.vhd(4): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at Pack.vhd(10): design library "ieee_proposed" does not contain primary unit "fixed_pkg" Error (10800): VHDL error at Pack.vhd(10): selected name in use clause is not an expanded name Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 4 errors, 1 warning Error: Peak virtual memory: 316 megabytes Error: Processing ended: Thu Sep 13 18:56:45 2012 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:02 Error (293001): Quartus II Full Compilation was unsuccessful. 6 errors, 1 warning I'm trying the alternative method. PS: Properties->library-> rtl_work, if i return to erase rtl_work from the Properties->library-> rtl_work, quartus compilates ok.
