14 years agoCould not find rtl_work.TB.vhd
Hello, The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design...
14 years ago --- Quote Start --- Leads to quartus compilation error: Error (10481): VHDL Use Clause error at producten.vhd(4): design library "ieee_proposed" does not contain primary unit "fixed_pkg" Error (10800): VHDL error at producten.vhd(4): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at pack.vhd(10): design library "ieee_proposed" does not contain primary unit "fixed_pkg" Error (10800): VHDL error at pack.vhd(10): selected name in use clause is not an expanded name Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 4 errors, 1 warning Error: Peak virtual memory: 316 megabytes Error: Processing ended: Thu Sep 13 18:56:45 2012 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:02 Error (293001): Quartus II Full Compilation was unsuccessful. 6 errors, 1 warning I'm trying the alternative method. PS: Properties->library-> rtl_work, if i return to erase rtl_work from the Properties->library-> rtl_work, quartus compilates ok. --- Quote End --- THIS ERROR IS POINTING TO MY PROJECT FILES INCLUDES!! But once again about ieeeproposed... The pack file is this: ------------------------------------------------------- -- Design Name : User Pakage -- File Name : Pack.vhd -- Function : Defines function for LFSR -- Coder : Alexander H Pham (VHDL) ------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; library ieee_proposed;
use ieee_proposed.fixed_pkg.all; USE ieee.std_logic_arith.all; use IEEE.std_logic_unsigned.all; package Pack is type info is array (1 to 78) of sfixed (1 downto -16);-- 78= 8*8 + 14/16 bordes type templates is array (1 to 9) of sfixed (1 downto -16); end; package body Pack is end package body; But also my main includes: library ieee_proposed;
with no error.
