16 years agoConvert a 50MHz clock into 1Hz Clock
I am working on a project that requires a counter. The ALTERA board that I am using has a 50 MHz clock on PIN N2. I wrote the following code for the counter:
module counter(clock, reset, count);
input clock, reset;
output count;
reg next_count,count;
always@*
begin
if(count<15)
next_count=count+4'd1;
else
next_count=count;
end
always@(posedge clock)
begin
if(reset)
count<=4'd0;
else
count<=next_count;
end
endmodule
I need to map the input clock to a 1 Hz clock so that the counter counts every second. But the board only has a 50 MHz clock. How can I use this 50 MHz as an input to the counter so that the counter counts every second? Please help .. Thanks!!!!3 Replies
to get 1Hz from 50MHz is very simple but depends on whether you want one 50% duy cycle 1Hz pulse or just one pulse of 50MHz period every 1 second.
all you need is one bit signal that goes high or low. for 50% duty cycle on the 50MHz counter: if count is at first half 50M then raise the signal else lower it if you want one pulse at 50MHz period only then: at any one chosen count value raise the signal else lower it. - Altera_Forum
--- Quote Start --- Simple question, lots of answers. The most straighforward way is to generate a 1Hz clock by using a counter: toggle the 1Hz clock every 25_000_000 cycles of the 50Mhz clock. A couple of issues. First, this will require a 23 bit counter running at 50 Mhz. You can use a PLL to generate a 100 kHz clock (PLLs have lower limits) and then use a counter to generate the 1 Hz clock from the 100 kHz clock. Also, at a 1 Hz it's not really a problem but ripple clocks are best avoided and replaced by clock enables. reg [9:0] counter; reg enable; always @ (posedge clk100k) begin if (counter == 10'd0) counter <= 10'd100_000; else counter <= counter - 1'd1; enable <= counter == 10'd0; end always @ (posedge clk100k) begin if (enable) begin // your logic here is run only once every second end end --- Quote End --- I was wondering if the following codes gonna work if I feed the clock input to the 50MHz clock. I ran a simulation on this code (I dont have the Altera board at home) and the report shows the code works. Please suggest...
Thanks Again!!!module Lab6a(clock, reset, cout); input clock, reset; output cout; reg count; //counts upto 50000000 reg cout; //original 4 bit counter always @ (posedge clock) begin if (~reset) begin if(count==50000000) begin count <= 0; cout = cout + 1; end else begin count <= count + 1; cout <= cout; end end else begin count <=0; cout <= 0; end end endmodule - Altera_Forum
