16 years agoConvert a 50MHz clock into 1Hz Clock
Hi, I am working on a project that requires a counter. The ALTERA board that I am using has a 50 MHz clock on PIN N2. I wrote the following code for the counter:
module counter(cloc...
16 years agoSimple question, lots of answers.
The most straighforward way is to generate a 1Hz clock by using a counter: toggle the 1Hz clock every 25_000_000 cycles of the 50Mhz clock. A couple of issues. First, this will require a 23 bit counter running at 50 Mhz. You can use a PLL to generate a 100 kHz clock (PLLs have lower limits) and then use a counter to generate the 1 Hz clock from the 100 kHz clock. Also, at a 1 Hz it's not really a problem but ripple clocks are best avoided and replaced by clock enables. reg [9:0] counter; reg enable; always @ (posedge clk100k) begin if (counter == 10'd0) counter <= 10'd100_000; else counter <= counter - 1'd1; enable <= counter == 10'd0; end always @ (posedge clk100k) begin if (enable) begin // your logic here is run only once every second end end
