16 years agoConvert a 50MHz clock into 1Hz Clock
Hi, I am working on a project that requires a counter. The ALTERA board that I am using has a 50 MHz clock on PIN N2. I wrote the following code for the counter:
module counter(cloc...
16 years agoto get 1Hz from 50MHz is very simple but depends on whether you want one 50% duy cycle 1Hz pulse or just one pulse of 50MHz period every 1 second.
all you need is one bit signal that goes high or low. for 50% duty cycle on the 50MHz counter: if count is at first half 50M then raise the signal else lower it if you want one pulse at 50MHz period only then: at any one chosen count value raise the signal else lower it.
