15 years agoConversion uses all combinational logic
I'm having trouble converting from an integer to an 8 bit std_logic_vector. It complies and gives an error that all my combinational logic nodes are used. I'm using a cyclone II FPGA chip.
type DATE_ARRAY is array(5 downto 0) of integer range 0 to 2100;variable SC_Var : std_logic_vector(7 downto 0) := x"00";
variable MN_Var : std_logic_vector(7 downto 0) := x"00";
variable HR_Var : std_logic_vector(7 downto 0) := x"00";
variable DT_Var : std_logic_vector(7 downto 0) := x"00";
variable MO_Var : std_logic_vector(7 downto 0) := x"00";
variable YR_Var : std_logic_vector(7 downto 0) := x"00";
variable DW_Var : std_logic_vector(7 downto 0) := x"00";date := ntpToRTC(timestamp_var);
SC_Var := std_logic_vector(to_unsigned(date(0),8));
MN_Var := std_logic_vector(to_unsigned(date(1),8));
HR_Var := std_logic_vector(to_unsigned(date(2),8)) or x"80";
DT_Var := std_logic_vector(to_unsigned(date(3),8));
MO_Var := std_logic_vector(to_unsigned(date(4),8));
YR_Var := std_logic_vector(to_unsigned(date(5),8));
DW_Var := "00000000"; The function I call fills the data with integers representing year, month, day... I also tried putting each conversion in a sepearate state and it made no difference. Any help much appreciated23 Replies
This wont be your problem, as FvM says type conversions use no logic (at the end of the day, an integer is still N bits). Do you have some loops in your code? recursive functions?
please post the rest of your code. - Altera_Forum
The question isn't understandable. A to_unsigned() conversion doesn't consume logic cells at all.
