15 years agoConversion uses all combinational logic
Hi, I'm having trouble converting from an integer to an 8 bit std_logic_vector. It complies and gives an error that all my combinational logic nodes are used. I'm using a cyclone II FPGA chip. ...
15 years agoQuartus will use an exclusive multiplier instance for d <= a*c, at least in most cases. It should be considered, that multiplexing a "single multiplier" to different signals also costs a lot of logic cells and is not necessarily an advantage in terms of overall resource usage.
In my opinion, sequential multiplexing is reasonable for a divider. As long as the utilized FPGA has free hardware multipliers, individual mutipliers are most likely the more economic variant. It may be slightly different with old FPGAs without hardware multipliers, e.g. Cyclone I. Looking at the resource usage of your original design, the large 31 and 32 bit wide dividers are causing most of the trouble. There are also options to code the problem more FPGA like, as the below example shows. The remaining two dividers for /100 and /400 are small and can be possibly accepted. To allow pipelining, the function needs to be rearranged as a component with clock input. Unfortunately, most resource usage is in the other functions.function getJulianDay (year: integer range 0 to 4095;
month: integer range 0 to 12;
day : integer range 0 to 31) return integer is
variable y: integer range 0 to 8191;
variable jd : integer range 0 to 2**22-1 := 0;
type m_tab is array (1 to 12) of integer;
constant am: m_tab := (1,1,0,0,0,0,0,0,0,0,0,0);
constant m153: m_tab := (306,337,0,31,61,92,122,153,184,214,245,275);
begin
y := year + 4800 - am(month);
jd := day + m153(month) + (365 * y);
jd := jd + (y/4) - (y/100) + (y/400) - 32045;
return(jd);
end getJulianDay;
