14 years agoconversion of std_logic (NOT std_logic_vector) to integer
Dear All, could someone advice, how to convert single bit information into integer so I could use it as index to an array? Conversion of std_logic_vector/unsigned/signed vectors is easy ...
10 years agoA quite workable solution is to use a
std_logic_vector(0 downto 0) as intermediate. This saves you the annoying "if (bit_x='1') then ...; else ...; endif;" Example: variable i: integer; variable a_bit : std_logic; variable a_bitx : std_logic_vector(0 downto 0); variable s: line; .. -- integer to bit: i := 1; a_bitx <= std_logic_vector(to_unsigned(i,1); a_bit <= a_bitx(0); -- long alternative: if i=1 then a_bit <= '1'; else a_bit <='0'; endif; -- and bit to e.g. text: write(s, to_integer(unsigned(a_bitx))); -- long alternative: if a_bit = '1' then write(s, string'("1")); else write(s, string'("0")); endif; NOTE: Often, in a testbench, the std_logic a_bit is not needed anymore if you use a_bitx(0) instead
