17 years agoConstraints from LVDS blocks and logic
Hi, I have a lvds tx and rx blocks in a Stratix3. There a 20 bits with deserialisation factor of 4. With the Rx side, the data leaving the lvds is registered. The lvds and registers are using c...
17 years agoThanks Rysc. I've tried the set_clock_uncertainty and it didn't make any difference to the output. I put a clock_uncertaintly setup on the lvds clock and the lvds enable. What I can say is that using the lvds enable (on c1 of the pll) for the logic as well, has improved it. If you consider a 64 bits bus split into 4 lanes, then we should get a 0707 pattern on each lane but instead we get the following (lane0 is bits 15 to 0, lane is bits 32 to 16 etc):
lane0: 0707 lane1: 0E07 lane2: 070E lane3: 0E07 All timing constraints have been met - setup and hold. I also have DPA on the lvds block which might be making things worse. I have tried all paths before and when the device gets full, it struggles to find the extra routing for the delay to meet any hold time requirements. I noticed that there a tcl commands called 'max_clock_arrival_skew' and 'max_data_arrival_skew'. Not sure if we can use these or not? Can tcl commands as .sdc commands - are they usable in this way? Thanks MT
