17 years agoConstraints from LVDS blocks and logic
Hi, I have a lvds tx and rx blocks in a Stratix3. There a 20 bits with deserialisation factor of 4. With the Rx side, the data leaving the lvds is registered. The lvds and registers are using c...
17 years agoThanks for the info.
When I say that I want a an external PLL, a pop-up box does appear but it states the clock requirements and that you need logic registers but nothing about multi-cycle constraints. However, in the ArriaGX FPGA's, if you do the same thing, it does come up with mc constraints that you must have. Interestingly enough, it doesn't include a hold constraint here either, only a set-up one. The clock is 156.25MHz, so, with serialisation factor of 4, we get the sclk to be 4 x 156.25 = 625MHz. The enable that the lvds block needs is 156.25MHz but with a 25:75 mark space ratio. Now, if I shift the sclk to +180 or -180 degrees and keep everything else at 0, there is no hold timing error and you can see the the sclk has shifted relative to the register clock. MT
