18 years ago
Constraining PLL output clocks
I was wondering how I am supposed to go about constraining the output clock(s) of a PLL. I have tried using the generated clock command but using this my design fails timing analysis. Is there a different command to be used, or are there additional conditions needed? Thanks.
    --- Quote Start ---
    So does derive_pll_clocks take care of both the input and output of the pll? Must I do anything additional to relate the source clock to the pll? Thanks for the reply.
    --- Quote End ---
    As I said, "derive_pll_clocks -create_base_clocks" will also do the create_clock for the PLL input for you. The -create_base_clocks argument is optional; you can do the create_clock for the PLL input yourself if you prefer.
    By the way, don't use the -use_tan_name argument. It creates clock names similar to those created by the Classic Timing Analyzer. If you are using strictly TimeQuest and want to use derive_pll_clocks (which I recommend), then stick with the TimeQuest naming convention.
    derive_pll_clocks will produce an "Info: Deriving PLL Clocks" message. The submessages will list the create_generated_clock commands and the optional create_clock command. As I said before, you can put these into your .sdc file instead of derive_pll_clocks if you want to use different clock names. If you don't leave derive_pll_clocks in your .sdc file, however, then be especially careful to watch for a PLL cross checking warning or to run check_timing and review the pll_cross_check result.
    From the on-line help:
    --- Quote Start ---
    derive_pll_clocks
    The following table displays information for the derive_pll_clocks Tcl command:
    tcl package and version
    Belongs to ::quartus::sdc_ext 1.0
    syntax
    derive_pll_clocks [-h | -help] [-long_help] [-create_base_clocks] [-use_tan_name]
    arguments
    -h | -help
    Short help
    -long_help
    Long help with examples and possible return values
    -create_base_clocks
    creates base clocks on input clock ports of the design that are feeding the pll
    -use_tan_name
    Use net names as clock names
    description
    Identifies PLLs or similar resources in the design and creates
    generated clocks for their output clock pins. Multiple generated
    clocks may be created for each output clock pin if the PLL is using
    clock switchover, one for the inclk[0] input clock pin and one for the
    inclk[1] input clock pin.
    by default this command does not create base clocks on input clock
    ports that are driving the pll. when you use the create_base_clocks
    option, derive_pll_clocks also creates the base clock on an input
    clock port deriving the pll. This option does not overwrite an
    existing clock.
    By default the clock name is the same as the output clock pin name.
    To use the net name (the same name the classic Timing Analyzer would
    use), use the -use_tan_name option.
    example usage
    project_open top
    create_timing_netlist
    # Create the base clock for the input clock port driving the PLL
    create_clock -period 10.0 [get_ports sysclk]
    # Create the generated clocks for the PLL.
    derive_pll_clocks
    update_timing_netlist
    # Other user actions
    report_timing
    delete_timing_netlist
    project_close
    return value
    Code Name Code String Return
    TCL_OK 0 INFO: Operation successful
    TCL_ERROR 1 ERROR: Timing netlist does not exist. Use create_timing_netlist to create a timing netlist.
    --- Quote End ---
    Use derive_pll_clocks. It creates the generated clocks for the PLL outputs. "derive_pll_clocks -create_base_clocks" will also do the create_clock for the PLL input for you.
    If you prefer to create the generated clocks yourself--for example, so that you can choose the clock names--then start with derive_pll_clocks. After you see the create_generated_clock commands it provides, you can put those into your .sdc file and change the clock names.
