17 years agoConstraining PLL in TimeQuest
Hello, I was waondering how to use derive_pll_clocks comand in TimeQuset. TimeQuest can't reflect new frequency. I did... 1.I grenarated SDC File from QSF File. 2.I changed input...
17 years agoThank you golgo. I followed your suggestion ,
and reflect new frequsnecy in TimeQuest's clock Summary. so I have a question. what's meaning of -use_tan_name in derive_pll_clocks Command? on-line help said -create_base_clocks: Creates base clocks on input clock ports of the design that are feeding the PLL -use_tan_name: Use net names as clock names I could understand -create_base_clocks, but I couldn't understand -use_tan_name.
