13 years agoConstrain SDR and DDR interface on the same interface
Hello, I have an IC that is outputting a databus with a center aligned clock. Depending on its mode, it is outputting in single data rate (up to 200MHz) or in dual data rate (up to 100MHz). ...
13 years agoThis is looking good in TimeQuest :).
Another small question: I get some hold violations on the paths from the FPGA pins to the first register where I clock the data on the falling edge. These hold violations are for the SDR clock and thus can be safely ignored. I was wondering how to specify these paths as false paths but only for the SDR clock. Something like this? set_false_path -from [get_ports {ddr_in[*]}] -fall_to sdr_ext_clk
