fogl
6 years agoConnection Setup for JTAG - simplification
Hello everybody, To use the JTAG on a MAX10 devices i should (according to UG-M10CONFIG) tie the JTAGEN and JTAG pins to either weak pull-up or pull-down. Is this actually really necessary. Can i c...
JohnT_Altera
6 years agoHi,
Yes, but I still recommend you to put weak-pull down on TCK pin so that the device is working correctly and avoid noise detected by the device. Other pin can be left floating.
