fogl
6 years agoConnection Setup for JTAG - simplification
Hello everybody, To use the JTAG on a MAX10 devices i should (according to UG-M10CONFIG) tie the JTAGEN and JTAG pins to either weak pull-up or pull-down. Is this actually really necessary. Can i c...
JohnT_Altera
6 years agoHi,
May I know if you are enabling JTAG Pin Sharing? If no the JTAGEN pin can be use as USER I/O pin. You may refer to Table 26 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
