17 years agoConnecting the Altera UART port to a development kits uart port
Hi I am working on a bluetooth(BT) development kit. The BT kit has a RS232 serial interface. I program the BT IC using hyperterminal [AT commands]. Now I need to connect the altera stratix ep1s10f780...
17 years agoI forgot to mention that the code works perfectly fine when connected to PC [using serial port] .. I can see the data being displayed on hyperterminal..and also i can type data from the hyperterminal.. however i cannot see the data when i plug my serial port into the bluetooth dev kit.. the development kit also is programmed using a rs232 port.. so i just replaced the pc with bluetooth dev kit.
altera ----> PC bluetooth kit ------> PC required connection bluetooth kit ------> altera
