11 years agoconnect two pll in serial to get 250MHZ clock
I have a Cyclone IV E FPGA with a 50MHZ oscillator , since this FPGA cannot generate more than 180 MHZ clock, I decide to get 125MHZ clock from one altpll , using this 125MHZ and then connect to anot...
11 years ago --- Quote Start --- I have a Cyclone IV E FPGA with a 50MHZ oscillator , since this FPGA cannot generate more than 180 MHZ clock, I decide to get 125MHZ clock from one altpll , using this 125MHZ and then connect to another altpll to get another 250MHZ cmos clock and output to outside world like ADC . Of course I got a critical warning after compiling , can I have this approach to get 250MHZ clock like this ? --- Quote End --- If you only want to generate clock to outside of the CIV, according to the datasheet, the max it can go is 472.5MHz directly to PLL clock output pin.
